How To Fix an iPhone 16 That Randomly Restarts
Revision as of 18:40, 5 July 2025 by VCCBoardRepairs (talk | contribs) (Created page with "{{Repair Guide |Device=IPhone 16, IPhone 16 Plus |Affects parts=Flex cable |Type=Teardown |Difficulty=1. Easy }} {{stub}} ==Problem description== There are many reasons that could cause an iPhone 16 and iPhone 16 Plus to randomly restart every few minutes. For the iPhone 16 Base Model series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own. The most common for iPhone 16 Base...")
Device IPhone 16, IPhone 16 Plus
Affects part(s) Flex cable
Needs equipment
Difficulty ◉◌◌◌ Easy
Type Teardown
The most common for iPhone 16 Base series are:
  • Bad Battery - If the battery is defective or goes bad, it can cause restarting problems.
For this model, look for where it says "SMC PANIC - ASSERTION FAILED" ... "Sensor Array" ..
If you see:
  • 3145728 and 2097152 - It's related to the Charging Port Flex
    • iPhone 16 Pro Max Air Pressure Sensor. If not connected or damaged, it will cause panic log 3145728
      Check the bottom mic/air pressure sensor module is connected
    • Test with OEM or Premium parts.
      • Aftermarket Flexes have a high defect rate
    • If water damaged:
      • 1. Check the taptic engine. You can test with it unplugged.
      • 2. Check the air pressure sensor module is not corroded or damaged
      • 3. Check the FPC for corrosion or loose pins
    • Diode mode the FPC connectors for any fault
    • iPhone 16 Pro Max - Charging Port Flex is Bad. Sensor Array 3145728
It is also a good idea to keep a known good charging port flex in your bench, for testing only. There are reports of even NEW flexes being bad. So you have to keep known good flexes on hand at all times, so you don't waste your time troubleshooting with possibly bad flexes.
  • Bad or damaged flex
Please note: You MUST have the required flex cables, (Charging port flex, etc) plugged in. Otherwise, it WILL restart. You cannot troubleshoot this step by unplugging the bad flex.
