How To Fix iPhone 4S With Short Battery Life
Revision as of 23:53, 6 November 2023 by VCCBoardRepairs (talk | contribs) (Updated formatting)
Device
Affects part(s)
Needs equipment
Difficulty
Type
Short battery life (instant death, irregular charge time, ect.)
  • Short battery life
  • instant death
  • irregular charge time
  • & other similar behavior
This is often caused by a bad battery.
  • Test another battery
  • - Remove the two P2 Screws at the bottom of the phone - push the back glass up towards the top of the phone. pull off glass gently.
  • - remove the two Philips 00 screws holding the battery connector on, (pay attention to placement of these screws)
  • - carefully remove pressure contact
  • - unclip battery connector
  • - pull battery tag ( if no tag, use 99% alcohol under the battery)
  • - place new battery, reassemble
