Xbox One S No Power
Revision as of 22:45, 29 June 2025 by Tiago199988 (talk | contribs) (Tiago199988 moved page Xbox One X No Power to Xbox One S No Power: Misspelled title)
Xbox One S No Power
Device Xbox One S
Affects part(s) Motherboard, PSU
Needs equipment Soldering Iron, Hot Air Station, Microscope, Multimeter
The Console does not turn on.
  • The console does not turn on
Usually an Xbox that shows no signs of life is due to a missing standby voltage.
The first voltage required is 12V, this line is produced from the power supply.
Connect your power supply to the motherboard and then to mains power with your multimeter measure the test point shown on the image below.
Xbox One S 12V input
If 12V is good we know the problem is not caused by the PSU.
The next important line to check is the 5V it is common to have a short here.
Xbox One S 5V Line
The next line to check is 1.1V
Xbox One S 1.1V Standby
The next line to check is 1.8V
Xbox One S 1.8V Standby
The last main standby voltage to check is 3.3V
Xbox One S 3.3V Standby
If you find a shorted line on the motherboard with your DCPS inject a voltage into that rail and monitor the board under a thermal camera the component that is shorted will heat up. Be careful not to inject a higher voltage than the line is rated for.
If you find a shorted line on the motherboard with your DCPS, inject a voltage into that rail and monitor the board under a thermal camera, the component that is shorted will heat up. Be careful not to inject a higher voltage than the line is rated for.
Shorted U4C3
If 12V is missing and the line is not shorted replace the PSU.
If 5V is missing and is not shorted replace U4C3.
If 1.1V is missing and is not shorted replace U4D4.
If 1.8V is missing and is not shorted replace U3D6.
If 1.8V is missing and is not shorted replace U4C2.
Final Testing
After repairing the console, make sure it turns on fully and runs a game.
