Redmi Note 13 4G Not Charging
Revision as of 21:50, 23 June 2025 by Ajimalg82 (talk | contribs)
Device Redmi Note 13 4G
Affects part(s) Logic Board
Type Soldering, BGA
The device works fine, turn on and its fully functional but does not achrge at all and the charging is not even detected.
  • Phone works but does not charge.
  • Turns on with new battery
  • Diode value on main connector is ok
  • Charging is not detected in on state or off state
  • Draw on AMP meter is 0.000V
Mainly this issue occurs with a faulty charger aur cable, in the result of this the device blows its OVP(Over Voltage Protection) ic to keep the device safe.
Note: Replacement of charger and charging cable is recommended after the repair.
To check all the voltages you have to plugin only the charger, battery is not required to check the following voltages.
  • Measure diode value on the charging FPC connector
  • Check voltage on VBUS 5.0 volt
Check VBUS
  • If 5.0 volt is present on the VBUS line then proceed to check the following components
  • Check if ovp ic is working:
    • Check the VBUS IN if is providing 5.0v
    • Check the VBUS OUT if its porviding the 5.0v output
OVP IC FUNCTION
  • If the VBUS OUT 5.0v is missing then proceed to the repair steps below.
  • Remove the OVP IC
  • Probe the pads to see there is no short to ground
  • if everything is ok then proceed to make a jumper bypass the OVP IC from VBUS _ OVP _ INPUT to VBUS _ OVP _ OUTPUT (shown in the picture below)
BYPASS OVP IC
  • Test if everything is working
  • Apply solder mask and your device should be ready
Solder mask applied
Ready
