Galaxy A125(Mediatek) No Graphics
Revision as of 20:51, 22 June 2025 by Ajimalg82 (talk | contribs) (galaxy a12 no graphicsrepair guide)
Device
Affects part(s)
Needs equipment
Difficulty
Type
The mobile phone turn on normally, vibrates, can hear sounds but cannot see anything on the screen (not to be confused with backlight issue) cannot see anything even with torch.
  • Device turns on normally
  • No light and no graphics
  • Can hear sounds
  • Charging is normal and can be detected on computer
There is a assential voltage for graphics that comes from PMIC that gets disconnected after several drops and the solution for this is that you have to make a small jumper to reconnect the disconnected pad in order to have it fully function again.
Check Diode value on this pin(if value is OL or high then proceed to the repair steps):
  • Lift up the PMIC
  • Check pad no.A17 if its disconnected, if not try to move it and see if it comes off or its lose (shown in picture below)
  • Make a jumper for the pad no.17 from the nearest component to the pmic (shown in picture below)
  • Your device should be fully working again.
