3 min reboot iPhone 16 panic log - 524288
Revision as of 01:07, 5 June 2025 by Oscarsphones (talk | contribs)
Device iPhone 16 / plus
Affects part(s) Charging port / air sensor
Needs equipment OEM replacement part
Difficulty
Type 3 min reboot panic log CODE 524288"3 min reboot panic log CODE 524288" is not in the list (Soldering, Teardown, Part replacement, Cleaning, Software, BGA, General) of allowed values for the "Repair Guide type" property.
"Easy" is not in the list (1. Easy, 2. Medium, 3. Hard, 4. Specialist) of allowed values for the "Repair Guide difficulty" property.
Does your iPhone 16 / plus restart every few minutes?
are you experiencing random shut offs?
follow this guide to find out why .
first: it’s important to make sure your phone is restarting every few minutes and NOT bootlooping.
If your phone doesn’t make it past the apple logo, it may be a problem with software / battery.
if your phone randomly shuts off constantly, this is known as a “panic” log
the phone reports a crash and stores the crash info inside of the settings app.
we will use this report to check the problem.
HOW TO CHECK PANIC LOG:
As soon as your phone boots up, immediately navigate to settings > privacy & security > analytics > analytic data
when you get here you’ll be presented with a bunch of reports. Don’t be overwhelmed, simply scroll down until you see the keyword “PANIC FULL”
there might be several. Look at the title for a date.
find the latest one and open it.
below I attached a photo highlighting what the “trigger code” is.
TRIGGER CODE: 524288
CHARGING PORT FLEX ISSUE
SOLUTION: REPLACE WITH ORIGINAL PULL PART.
IMPORTANT!! AIR SENSOR MUST BE PLUGGED IN TO STOP THE REBOOT. IF REBOOT PERSIST REPLACE AIR SENSOR
IF IT STILL PERSISTS , CHECK FPC CONNECTOR PINS FOR ANY SHORTS.
Keep in mind: partially unplugged charging flex can trigger reboot, check carefully no debree or small damage exists in the charging port FPC.
a simple replacement fixes this issue.
- Randomly restarts
- constantly reboots
- Possibly no loud speaker
- possibly not charging
Option 1 Replace charging port
Option 2 MAKE SURE AIR SENSOR IS PLUGGED IN
option 3 Replace air sensor
option 4: Check FPC connector for any faults
