IPhone 15 Pro Stuck at 1 Percent Charging and No Battery Data 0xa1 Panic Log Code
Revision as of 21:03, 4 June 2025 by VCCBoardRepairs (talk | contribs) (15 Pro not charging solution in progress)
Device IPhone 15 Pro, IPhone 15 Pro Max
Affects part(s)
Difficulty ◉◉◉◉ Specialist
Type Soldering, BGA
iPhone 15 Pro that is not charging. It says it is at 1% battery level & doesn't go up. The USB meter is constantly fluctuating. When you plug in the charging cable, it pops up as 0% remaining.
It also restarts every 3 minutes due to lack of battery data. The panic log error will be 0xa1.
Even with a new battery and charging port installed, the symptoms will remain the same.
This tends to happen when the phone gets water damaged & fries the PMIC.
15 Pro 0xa1 Panic Log Example
Figure 1 - iPhone 15 Pro 0xa1 Panic Log Example
  • Not Charging at 9V
  • USB Meter is fluctuating
  • Always reads battery at 1%
  • When plugging in the charger, it says 0% remaining
  • Restarts every 3 minutes
  • Panic Log Error code is 0xa1 (Figure 1)
  1. Test with known good parts. Specifically battery & charging port
  2. Check the battery connector for damage. The pins should all be straight & not bent, warped or missing
  3. Check the connector Diode Mode Values: ZXW Pin 1: 0.439V I2C2_SMC_CHARGER_BI_GG_SDA_1V8 ZXW Pin 2: 0.548 I2C2_SMC_CHARGER_TO_GG_SCL_1V8_CONN ZXW Pin 5: OL ANALOG_BATT_VCELL_NEG_CONN ZXW Pin 6: 0.505V ANALOG_BATT_VCELL_POS_CONN
    iPhone 15 Pro FPC Connector Diode Mode Values
  4. Check the voltage of the battery connector pins, by connecting the board only, with charging port flex. Then plug in the charger to it & measure each pin: ZXW Pin 1: 1.5V I2C2_SMC_CHARGER_BI_GG_SDA_1V8 ZXW Pin 2: 1.8V I2C2_SMC_CHARGER_TO_GG_SCL_1V8_CONN ZXW Pin 5: 0.6V ANALOG_BATT_VCELL_NEG_CONN ZXW Pin 6: 0.6V ANALOG_BATT_VCELL_POS_CONN
    iPhone 15 Pro Board & Charging Port. How to measure the voltage at the battery connector
If you have a bad diode mode reading or low voltage on the battery connector, it's likely PMIC that has failed.
