| How To Fix an iPhone 14 That Randomly Restarts | |
| Device | iPhone 14, iPhone 14 Plus |
| Needs equipment | Screwdrivers, known good parts, spudger |
| Type | Part replacement |
There are many reasons that could cause an iPhone 14 and iPhone 14 Plus to randomly restart every few minutes. For the iPhone 14 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 14 series are:
- Back Glass/Wireless Charging Flex- This is the flex that is attached to the Back Glass. It can damaged during a drop or screen replacement
- After a hard drop, the iPhone will restart every 3 minutes.
If you see:
- 0x400000 - it's the Wireless Charging Flex (Back Glass)
- Make sure it's plugged in & the flex is not torn
- Bad or damaged flex
