How To Fix an iPhone 16 Pro That Randomly Restarts
Revision as of 01:37, 22 May 2025 by VCCBoardRepairs (talk | contribs) (added taptic engine note)
Device IPhone 16 Pro Max, IPhone 16 Pro
Affects part(s) Flex cable
Needs equipment
Difficulty ◉◌◌◌ Easy
Type Teardown
There are many reasons that could cause an iPhone 16 Pro and iPhone 16 Pro Max to randomly restart every few minutes.
For the iPhone 16 Pro series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 16 Pro series are:
  • Bad Battery - If the battery is defective or goes bad, it can cause restarting problems.
For this model, look for where it says "SMC PANIC - ASSERTION FAILED" ... "Sensor Array" ..
If you see:
  • 3145728 - It's the Charging Port Flex
    • If water damaged, check the taptic engine. You can test with it unplugged.
    • Diode mode the FPC connectors for any fault
    • iPhone 16 Pro Max - Charging Port Flex is Bad. Sensor Array 3145728
It is also a good idea to keep a known good charging port flex in your bench, for testing only. There are reports of even NEW flexes being bad. So you have to keep known good flexes on hand at all times, so you don't waste your time troubleshooting with possibly bad flexes.
  • Bad or damaged flex
Please note: You MUST have the required flex cables, (Charging port flex, etc) plugged in. Otherwise, it WILL restart. You cannot troubleshoot this step by unplugging the bad flex.
