| How To Fix an iPhone 12 That Randomly Restarts | |
| Device | iPhone 12 |
| Needs equipment | Screwdrivers, known good parts, spunger |
| Type | Part replacement |
There are many reasons that could cause an iPhone 12 Mini, iPhone 12, iPhone 12 Pro and iPhone 12 Pro Max to randomly restart every few minutes. For the iPhone 12 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 12 series are:
- Bad or Defective Battery - If the phone is not showing a percentage at the top of the screen, it means the battery data isn't being read by the device, causing the device to restart.
- Charging Port Flex - This is the flex towards the bottom of the phone which is slightly exposed behind the back glass. It is easily damaged with a drop & broken back glass, or by a technician during a back glass repair .
If you see:
- Check the battery data pins (I2C2_SMC_SDA_1V8 and I2C2_SMC_SCL_1V8) for a diode mode reading. If it's OL, then there's a disconnected line & it'll need to be investigated.
- Check for missing missing resistors around the battery connector, like R2473, R2472, R2475.
- Bad or damaged flex
