How To Fix an iPhone XS That Randomly Restarts
Revision as of 17:00, 5 November 2023 by ASRepairs (talk | contribs)
Device iPhone XS, iPhone XS Max
Difficulty ◉◌◌◌ Easy
Type Part replacement
There are many reasons that could cause an iPhone XS and iPhone XS Max randomly restart every few minutes. For the iPhone XS & XS Max there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone XS Series is:
  • Bad or Defective Battery - If the phone is not showing a percentage at the top of the screen, it means the battery data isn't being read by the device, causing the device to restart. So if you see your iPhone XS says it's charging at 0%, that could be why it's restarting.
  • Charging Port Flex - This is the flex towards the bottom of the phone which is slightly exposed behind the back glass. It is easily damaged with a drop & broken back glass, or by a technician during a back glass repair.
  • After a battery replacement, the iPhone will bootloop every 3 minutes
An example panic log, showing "Missing sensors: Prs0", which means it has a bad charging port flex.
If you see:
  • TG0B or TG0V - It's battery related:
    • The battery is defective or has failed
    • The battery connector itself is damaged, warped or broken
    • The battery connector data lines are missing.
      • Check the mosfets Q3201 or Q3200 to see if broken or damaged
      • Check the battery data pins (I2C0_SMC_TO_GG_SCL_CONN and I2C0_SMC_BI_GG_SDA_CONN) for a diode mode reading. If it's OL, then there's a disconnected line & it'll need to be investigated
  • Prs0 or Mic1 - It's the charging port flex.
    • Test with known good charging port flex.
    • Check for damaged or missing resistors around the charging port connector
  • Bad or damaged flex
