MacBook Pro A1706 PP3V3 G3H short repair
Revision as of 19:01, 30 October 2023 by ASRepairs (talk | contribs)
Device MacBook Pro A1706
Affects part(s) Motherboard
Missing PP3V3_G3H on A1706 MacBook Pro
  • MacBook not turning on.
  • Not charging
  • A CD3215 is short circuited to ground, will show up instantly on thermal camera which one it is.
  • CB300 corroded, but you can't see it because it is hiding under the metal around the NAND. LOOK CLOSELY!
  • Some other random component, but check CB300 first.
