Hum or rev noise when running vehicle
Revision as of 08:58, 9 March 2025 by Coretsh (talk | contribs) (Created page with "{{stub}} {{Repair Guide |Device=2002 ES300 |Affects parts= |Needs equipment= |Type= |Difficulty= }} == Problem description == When listening from outside vehicle noise not herd. Inside vehicle noise is herd from body. thumb|Example image (Figure 1) -- No image yet. Help expand this page by uploading it! == Possible areas of Problem: == * Possible areas of problem: With stethoscope listen to fuel pressure damper set (on fuel rail). If pu...")
Device 2002 ES300
Affects part(s)
Needs equipment
Difficulty
Type
  • Possible areas of problem: With stethoscope listen to fuel pressure damper set (on fuel rail). If pulsation is herd suspect damper
Fuel Pressure Pulsation Damper Assy was the problem
Replace Fuel Pressure Pulsation Damper
