How To Fix an iPhone 14 That Randomly Restarts
Revision as of 23:28, 19 February 2025 by J.page (talk | contribs) (Added panic sensor array code for MLB/interposer, added clarification related to combined sensor array codes being added together when displayed.)
Device iPhone 14, iPhone 14 Plus
Difficulty ◉◌◌◌ Easy
Type Part replacement
There are many reasons that could cause an iPhone 14 and iPhone 14 Plus to randomly restart every few minutes.
For the iPhone 14 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
If certain parts are unplugged, you may also face restarting problems.
The most common for iPhone 14 series are:
  • Back Glass/Wireless Charging Flex- This is the flex that is attached to the Back Glass. It can damaged during a drop or screen replacement
  • Proximity Flex -This is the flex that is attached to the screen. It can easily be liquid damaged or torn during a screen replacement.
  • iPhone 14 With Back Glass unplugged. This causes 3 min restart. Panic Log Code 0x400000
    After a screen repair, the iPhone will bootloop every 3 minutes
iPhone 14 With Charging Port unplugged. This causes 3 min restart. Panic Log Code 0x100000
If you see:
  • 0x400000 - it's the Wireless Charging Flex (Back Glass)
      Make sure it's plugged in & the flex is not torn
    • Could be a sandwich issue
  • iPhone 14 Panic Log Example. Charging Port Flex unplugged. This causes 3 min restart. Panic Log Code 0x100000
    0x100000 - it's the Charging Port Flex
  • 0x500000 - it's a communication problem with the battery
    • the battery has a communication issue while charging
    • restarts every 3min30sec
    • test with another battery
    • check diode values on battery connector on the motherboard
  • 0x500000 - Or it could be the taptic engine as well as the charging port flex
  • iPhone 14 Panic Log Example. Prox Flex unplugged. This causes 3 min restart. Panic Log Code 0x200000
    0x200000 - it's the Proximity Flex Cable
      iPhone 14 With Proximity Flex unplugged. This causes 3 min restart. Panic Log Code 0x200000
  • 0x600000 - it's wireless Charging flex + proximity Flex Cable
    • check with original known good flex
    • both must be connected to the motherboard
  • 0x20000 - It's the logic board.
    • Likely a disconnection of the logic board interposer (middle layer of the sandwich board).
    • Inspect edges of logic board for gaps between the layers.
    • This will likely require in-depth board repair and specialized tools for safely heating the board.
It's important to note that any combination of the above codes is possible. They are presented as hex and will be added together at times, giving you another code that won't always be listed here. (ex. 0x600000 will be shown when both the Proximity Flex AND Wireless Charging Flex are not detected.)
When troubleshooting these issues, make sure the flexes listed above are all plugged in. You cannot test for restart problems by unplugging the flex cables.
It is also a good idea to keep known good parts on your bench, for testing only.
There are reports of even NEW flexes being bad. So you must keep known good flexes on hand at all times, so you don't waste your time troubleshooting with possibly bad flexes.
Always make sure to replace the appropriate flex with an OEM or Premium parts. Don't use aftermarket parts.
In scenarios where you have the appropriate flexes plugged in (listed above), but it still restarts, then you either have:
  • Bad or damaged flex
