MacBook Pro A1707 Not charging repair
Revision as of 16:07, 29 October 2023 by ASRepairs (talk | contribs)
Device MacBook Pro A1707
Affects part(s) Charger
Needs equipment None
Difficulty ◉◌◌◌ Easy
Type Software
Fixing an issue with A1707 TouchBar MacBook Pro that is not charging properly.
  • Discharge during normal operation
  • Won't charge during normal operation when plugging in charger
  • Won't charge when turned off
Charger may have gone on strike. Unplug charger from AC and from Laptop, wait a few seconds, try again. Try a different port on MacBook (the problem with the other port will go away automatically).
SMC problems may prevent charging at all. When turned off, perform an SMC reset
