APC Back-UPS 600VA
Revision as of 00:33, 17 October 2024 by The Cre8r (talk | contribs) (Create new repair page)
APC Back-UPS 600VA
Manufacturer APC
Code name
Release date
Device type Other
30 AMP FUSE REPLACEMENT
The board has two 30-amp blade-style fuses that may go bad. If the device has a known good battery and has the symptoms of "Replace Battery" per the user guide. To replace the fuse:
  • Remove the battery and battery cover
  • Remove the 4 Phillips screws
  • Remove the back cover
  • Disconnect all connectors on the main board and remove the main board.
  • Test continuity on each 30-amp fuse.
  • Desolder and resolder a new 30-amp blade-style fuse for the one without continuity.
  • Place the main board back and reconnect all connectors.
  • Return battery wires through labeled openings on the back cover and reinstall.
  • Screw in 4 screws.
  • Install battery and cover.
  • Complete.
Internal Fuse (2x) - 30 Amp Blade Style
Battery - APCRBC110
Product Page: https://www.apc.com/us/en/product/BN600G/apc-backups-600va-120v-8-outlet-retail/
User Guide: https://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=AHUG-8XM8V4_R1_EN.pdf&p_Doc_Ref=SPD_AHUG-8XM8V4_EN
