Steam Deck - Replace shoulder switch R1/L1 | |
Device | Steam Deck |
Affects part(s) | Controller Board rev. B |
Needs equipment | Soldering Iron, replacement switch |
Difficulty | |
Type |
"intermediate" is not in the list (1. Easy, 2. Medium, 3. Hard, 4. Specialist) of allowed values for the "Repair Guide difficulty" property.
A common problem with the controller board of the Steam Deck LCD are the shoulder switches, that can break off easily during disassembly.
There are multiple compatible replacement switches. On Aliexpress they are sold as "Steam Deck switch" or "XBOX 360 pair switch".
Those switches have three pins and two legs (the latter for mounting through the pcb).
Swapping of the switches should be self-explanatory.
In case the signal pads on the pcb get damaged:
On each controller board the leftmost and rightmost pin of the switch is connected to the ground plane of the board.
The middle pin is connected to the MCU/a signal multiplexer. On the left controller board you can strip the solder mask of the trace, running to the middle pin of the switch or connect the middle pin of the switch to the corresponding testing point for the L1 switch (see figure 1 and 2).
On the right controller board, the middle pin is connected to the testing point visualised in figure 3.
