- Power / Yellow
- Charging / Green
- Power Fault / Red
- Charging Fault / Red
Relay / contactor information
Notes:
- high-current terminals may be label L for Line and T for Terminus (load) but it actually doesn't matter
- When terminating the high-current wires into it, crimp ferrules onto the wire ends.
| Make | Model | info / link | info / link | suitability / notes |
| Hongfa | XMC0-402.IBBD | website | contactors catalog (PDF) | reference, used by OEM
60mm H x ~80mm L x ~50mm W coil terminal tabs are splayed no coil cover |
| American Zettler | XMC0-402.IBBx (x=C or D, terminal type per data sheet below) | RS Online (out of stock) | DigiKey (high volume only, long lead) | unknown but likely highest quality
has manual button override |
| American Zettler | XMC0-402.ID | data sheet from Zettler | DigiKey ($10 for qty 1) |
| Appli Parts | APAC-240240 | Amazon, $21 |
| CGELE | UPC 774297736354 | Amazon, $12 | inspected Aug 2024:
| BlueStars | LTC-2S-40 / 2P-40A-240V | Amazon, $13 | inspected Aug 2024:
| Homer | XMC0-402.IBBx (x=C? D?) | unknown | ||
| Packard | C240C | unknown |
Background / failure modes
- inadequate strain relief at J1772 plug handle inlet, leading to broken wire inside
- High ground leakage
A common problem with Level 2 EVSEs in general is that the contactor welds itself closed. Typically not an issue with ClipperCreek though. OpenEVSE chargers like to do this later in life. After taking it apart and filing down the welds on the contact faces, you start just banging your fist on it real hard a couple times. Then power cycling it. That fist induced vibration was usually enough to break those welds, power cycle to clear the error, and get it working again for another month. Before it welded itself again. (will move this to OpenEVSE page later)
More product photos
