ClipperCreek HCS series
Revision as of 20:51, 10 October 2024 by ChrisC (talk | contribs) (contactor evaluation results (batch 2))
(up to EV chargers section)
  • Power / Yellow
  • Charging / Green
  • Power Fault / Red
  • Charging Fault / Red
Relay / contactor information
Hongfa contactor seen in actual unit
Notes:
contactors for HCS series
60mm H x ~80mm L x ~50mm W
coil terminal tabs are splayed
no coil cover
has manual button override
American Zettler XMC0-402.ID data sheet from Zettler DigiKey ($10 for qty 1) same as Zettler above but with "standard thermoset frame" instead of "compact thermo plastic frame"
evaluated Aug 2024
  • visually looks the same
  • 66mm H x 84mm L x 50mm W
  • coil is covered
Appli Parts APAC-240240 Amazon, $21 evaluated Aug 2024
  • 65mm H x 82mm L x 55mm W
  • exposed coil
CGELE UPC ‎774297736354 Amazon, $12 evaluated Aug 2024
  • 65mm H x 88mm L x 53mm W
  • exposed coil
BlueStars LTC-2S-40 / 2P-40A-240V Amazon, $13 evaluated Aug 2024
  • 65mm H x 82mm L x 53mm W
  • exposed coil
Packard C240C unknown
Background / failure modes
  • High ground leakage
A common problem with Level 2 EVSEs in general is that the contactor welds itself closed. Typically not an issue with ClipperCreek though. OpenEVSE chargers like to do this later in life. After taking it apart and filing down the welds on the contact faces, you start just banging your fist on it real hard a couple times. Then power cycling it. That fist induced vibration was usually enough to break those welds, power cycle to clear the error, and get it working again for another month. Before it welded itself again. (will move this to OpenEVSE page later)
More product photos
inside view of HCS series EVSe, with back cover removed
lone PCBA inside the HCS series EVSE
