- Power / Yellow
- Charging / Green
- Power Fault / Red
- Charging Fault / Red
Relay / contactor information
Two of the fault codes above involve a failed contactor, one of the few mechanical items in the assembly and thus more prone to failure. This part is a 40-Amp, 2-pole contactor with metal mounting plate and screw terminal capability. (Here's a basic intro into what a contactor is and how it works.) When terminating wires into it, crimp ferrules onto the wire ends.
| Make | Model | info | info | suitability |
| Hongfa | XMC0-402.IBBD | website | contactors catalog (PDF) | used by OEM |
| American Zettler | XMC0-402.IBBx (x=C or D, terminal type per data sheet below) | RS Online (out of stock) | DigiKey (high volume, long lead) | unknown but likely highest quality |
| American Zettler | XMC0-402.ID | data sheet from Zettler | DigiKey ($10 for qty 1) | same as Zettler above but with "standard thermoset frame" instead of "compact thermo plastic frame" |
| Homer | XMC0-402.IBBx (x=C? D?) | unknown | ||
| Packard | C240C | unknown | ||
| Appli Parts | APAC-240240 | Amazon, $21 | cheap crap? being evaluated Aug 2024 | |
| CGELE | UPC 774297736354 | Amazon, $12 | cheap crap? being evaluated Aug 2024 | |
| BlueStars | LTC-2S-40 / 2P-40A-240V | Amazon, $13 | cheap crap? being evaluated Aug 2024 |
Background / failure modes
- High ground leakage
More product photos
