| How To Fix an iPhone 11 That Randomly Restarts | |
| Device | iPhone 11 |
| Needs equipment | Screwdrivers, known good parts, spudger |
| Type | Part replacement |
There are many reasons that could cause an iPhone 11 randomly restart every few minutes. For the iPhone 11, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 11 series are:
- Bad or Defective Battery - If the phone is not showing a percentage at the top of the screen, it means the battery data isn't being read by the device, causing the device to restart. So if you see your iPhone 11 says it's charging at 0%, that could be why it's restarting.
- Damaged or Defective Power Button - There is a secondary mic (mic2) that is on the power button flex. It is easily damaged, especially after back glass repair, causing the mic to be disconnected & the phone will restart when it's not detected.
- Motherboard Sandwich Separation - If an iPhone 11 has a hard drop, it can cause the 2 layer sandwich to separate, which will disconnect the mic2 line from the power button flex, as that connect is on the bottom board. So it may need a sandwich reball to repair it.
If you see:
- Check the battery data pins (I2C2_SMC_SCL_CONN and I2C2_SMC_SDA_CONN) for a diode mode reading. If it's OL, check the resistors R3202 and R3201 for damage. Otherwise, the disconnection could be under the CPU & requires a CPU reball. If you get a short, then check the caps around the connector. Otherwise, the short is within the CPU likely not fixable.
- Make sure it's plugged in & the flex is not torn
- Check that there's no liquid damaged, or that it's defective
- Check R6822 (I2C1_AOP_SCL) and R6823 (I2C1_AOP_SDA) resistors
- Mic2 - It's related to the mic on the power button flex
- Test with a known good power button flex
- Check for pry damage on all the small components near the connector
- Diode mode the power button connector & see if you get an OL. If so, you may have to split the sandwich and check for mic2 lines and ripped pads. You may need to reball the sandwich to fix it.
- Bad or damaged flex
