ClipperCreek HCS series
Revision as of 14:25, 24 July 2024 by ChrisC (talk | contribs) (holy s--t, it's case sensitive :()
(up to EV chargers section)
Information about DIY repair of the ClipperCreek HCS series, which includes the HCS-40 and HCS-60 models.
Link to Clipper Creek manual with LED codes table
- High ground leakage
