| Xbox Series X powers off shortly after powering on repair | |
| Device | Xbox Series X |
| Needs equipment | |
Automatic Shutdown after pressing the power button.
- Powers off shortly after powering on
- Automatic Shutdown after pressing the power button.
- Shutdown within 3 seconds: Short on 12v power rails.
- Shutdown within 10 seconds: Short on APU power rails.
If shorts are found on the rails' capacitors, it is probably a chip surrounding them instead of the capacitors themselves. Try to remove surrounding chip one by one and test if the shorts are still there until you find the faulty chip.
If you just replaced the HDMI port, double check your work and make sure you don't have any pins bridged.
Alternatively: Check location U82 on the main board for a short (The board that has the HDMI port on it). It is on the backside of the board, on the reverse side of the HDMI port. On then off can occur when replacing HDMI port. The chip in question uses the SOT-23-5 package. STMPS2151STR is the original replacement part for this chip. TPS2065DBVR & AP2151D appear to be viable replacements as well. A data sheet for the AP2151D chip to view the pinout is available here: https://www.diodes.com/assets/Datasheets/AP2141D_51D.pdf
