| Apple T2 platform | |
| Device(s) | Apple Laptops |
Devices using T2 / T8012 SoC
All Intel MacBooks 2018-2020
Mac Pro 2019
iMac 2020, iMac Pro
Mac Mini 2018
Theory
Main functions:
- Encryption processor: T2 has Apple's own security enclave processor (SIP), which is used for encryption, payment verification, authentication, and Touch ID.
Firmware
Power Sequence
- T2-Calpe power stage:
T2 Power diagram
