Apple T2 platform | |
Device(s) | Apple Laptops |
Devices using T2 / T8012 SoC
All Intel MacBooks 2018-2020
Mac Pro 2019
iMac 2020, iMac Pro
Mac Mini 2018
Theory
Apple introduced T2 or T8012 in 2018 and discontinued it in 2020, fully fused into the M1 CPU. T2 is essentially a second processor used at the low level of the board, similar to SIO/EC on PC laptops; it serves as a board supervisor device. The most important aspect in repair would be its power state control and role in the power sequence. This chip is very close to the iPhone A10 SoC and was likely introduced as a bridge step to the Apple Silicon platform (its OS is even called BridgeOS, which is a huge hint). Understanding the T2 platform is key to understanding the M1+ platform, as well as the basics of Apple hardware design. Understanding T2/iBoot/BridgeOS platform will also help you to effectively read power sequence. Main functions:
- Encryption processor: T2 has Apple's own security enclave processor (SIP), which is used for encryption, payment verification, authentication, and Touch ID.
Firmware
Power Sequence
- T2-Calpe power stage:
- Main T2 power states, "S2", "SLP" (not relevant to the Intel platform!), Intel S5-S3-S0 power sequence.
- Rails like CPU VCORE, VCCGT, etc.
