Apple T2 platform
Revision as of 23:32, 31 March 2024 by ASRepairs (talk | contribs)
Apple T2 platform
Device(s) Apple Laptops
Devices using T2 / T8012 SoC
All Intel MacBooks 2018-2020
Mac Pro 2019
iMac 2020, iMac Pro
Mac Mini 2018
Theory
Apple introduced T2 or T8012 in 2018 and discontinued it in 2020, fully fused into the M1 CPU. T2 is essentially a second processor used at the low level of the board, similar to SIO/EC on PC laptops; it serves as a board supervisor device. The most important aspect in repair would be its power state control and role in the power sequence. This chip is very close to the iPhone A10 SoC and was likely introduced as a bridge step to the Apple Silicon platform (its OS is even called BridgeOS, which is a huge hint). Understanding the T2 platform is key to understanding the M1+ platform, as well as the basics of Apple hardware design. Understanding T2/iBoot/BridgeOS platform will also help you to effectively read power sequence. Main functions:
  • SMC block: Battery charging, sensors management, power enables, and Intel S0-S5 state control.
  • SSD Controller: The T2/M1 MacBook SSD is essentially a sort of RAID array built on custom-produced Toshiba/Hynix SIP (System in Package) SSDs. Each SSD on board (often called NAND, which is technically not correct) contains its RAID configuration block. To read more, refer to the (upcoming) MacBook SSD Repair page.
  • Encryption processor: T2 has Apple's own security enclave processor (SIP), which is used for encryption, payment verification, authentication, and Touch ID.
  • eSPI controller: The Intel EFI image is stored on the T2 firmware service partition as a file; it is fed to the PCH via the eSPI interface. For example to clean ME region after Intel SoC/PCH replacement you need to use DFU Revive in Apple Configurator. This will practically rebuild EFI image on BridgeOS partition
  • Camera, Keyboard/Trackpad, Touchbar, Audio controller: Being basically a repurposed iPhone CPU, Apple reuses the audio codec, screen controller, and USB interfaces.
  • Power Controller: T2 is paired with a universal configurable power IC called CALPE. This chip has dozens of integrated buck regulators, LDOs. Unlike old platforms, it does not have direct enable signals but is controlled via the i2c interface. T2 itself also controls the GPU power sequence and gMUX.
  • Debug interfaces. T2 is also capable of feeding iBoot log as well as PCH/EFI Log into USB. It was used by Quanta with so called Potassium cable which worked as a debug terminal to read boot log of T2 / Intel PCH. Unfortunately since 2018 iBoot leak, Apple encoded all messages into stripped hashed message which cant be decoded. However PCH log is extrimely useful since it can pinpoint issue to RAM, GPU or other component depending on stalled block of EFI. It also shows full AHT log(Diagnostics on D button on start), listing all sensors and their values.
Firmware
Power Sequence
  1. "Finite state" stage, which does not require any activity from T2:
    • Main G3H power state generators, PPBUS, PP3V3_G3H_RTC.
  2. T2-Calpe power stage:
    • Main T2 power states, "S2", "SLP" (not relevant to the Intel platform!), Intel S5-S3-S0 power sequence.
  3. Intel Power stage (controlled by PCH/CPU System Agent):
    • Rails like CPU VCORE, VCCGT, etc.
