There are many reasons that could cause an iPhone 14 and iPhone 14 Plus to randomly restart every few minutes.
For the iPhone 14 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 14 series are:
Back Glass/Wireless Charging Flex- This is the flex that is attached to the Back Glass. It can damaged during a drop or screen replacement
Proximity Flex -This is the flex that is attached to the screen. It can easily be liquid damaged or torn during a screen replacement.
Charging Port Flex - This is the flex towards the bottom of the phone. It is easily damaged with a drop & the back glass is breaks. Or when someone has repaired the back glass.
After a back glass repair, the iPhone will restart on its own every few minutes
After a hard drop, the iPhone will restart every 3 minutes.
iPhone 14 With Back Glass unplugged. This causes 3 min restart. Panic Log Code 0x400000After a screen repair, the iPhone will bootloop every 3 minutes
The iPhone will reboot randomly when using it.
The iPhone will seem to freeze and restart every 2-5 minutes.
iPhone 14 With Charging Port unplugged. This causes 3 min restart. Panic Log Code 0x100000
If you see:
0x400000 - it's the Wireless Charging Flex (Back Glass)
iPhone 14 With Back Glass unplugged. This causes 3 min restart. Panic Log Code 0x400000Make sure it's plugged in & the flex is not torn
Check that there's no liquid damaged, or that it's defective
Test with OEM or Premium. Aftermarket Flexes have a high defect rate
Diode mode the FPC connectors for any faults
Could be a sandwich issue
iPhone 14 Panic Log Example. Charging Port Flex unplugged. This causes 3 min restart. Panic Log Code 0x1000000x100000 - it's the Charging Port Flex
0x500000 - Check the taptic engine as well as the charging port flex
Make sure this flex is plugged in
Check that no flex is torn, liquid damaged, defective
iPhone 14 Panic Log Example. Prox Flex unplugged. This causes 3 min restart. Panic Log Code 0x2000000x200000 - it's the Proximity Flex Cable
iPhone 14 With Proximity Flex unplugged. This causes 3 min restart. Panic Log Code 0x200000Diode mode the FPC connectors for any faults
Bad or damaged flex
Low quality aftermarket flex
Other flex cables that are Liquid Damaged
