IPad 7 Not Turning On Error 4013 Repair
Revision as of 06:10, 21 January 2024 by KevinShort (talk | contribs)
Device iPad 7
Affects part(s) Motherboard
Needs equipment Soldering equipment
Difficulty ◉◉◉◉ Specialist
Type BGA, Soldering
Diagnosis and repair of an iPad 7 that does not boot. Device may give error 4013 when trying to update or restore through iTunes.
  • Boot looping on the Apple logo.
  • iPad may not show any sign of life at all.
  • Passes tristar tester.
This device is notorious for having CPU related issues. The logic board flexes and tends to disconnect traces under the CPU causing this issue. Reballing the CPU can sometimes fix the issue, but the CPU also can just fail altogether. Seems to be a very common defect for this model.
