How To Fix an iPhone 7 That Does Not Turn On, urrent jumps back and forth from 0 A to 320 mA, then 0 A to 1.4 A, then 0 A to 500 mA, and so on
| How To Fix an iPhone 7 That Does Not Turn On, urrent jumps back and forth from 0 A to 320 mA, then 0 A to 1.4 A, then 0 A to 500 mA, and so on | |
| Device | IPhone 7, IPhone 7 Plus |
| Type | BGA, Soldering |
- Symptom 1 (Figure 1)
- Symptom 2
