| How to Fix an iPad Pro 10.5 That Randomly Restarts | |
| Device | IPad Pro 10.5 |
| Affects part(s) | motherboard |
| Needs equipment | |
There are a couple of common reasons that could cause an iPad Pro 10.5 to restart randomly or every few minutes. The two most common problems are:
- Loose or Broken Coils (Inductors) - These can break or fall off the logic board after a drop.
- Screen - A bad display can cause the iPad to restart every 60 seconds.
- The iPad will reboot randomly when using it.
- After a screen repair the iPad will restart every minute.
- After a hard drop the iPad will restart on its own.
If the issue has a single, specific solution, provide it in this section and delete the sub-headers below. Otherwise, if there are multiple potential causes for the problem, outline the process of identifying the root cause and offer corresponding solutions below. There are a few common faults that cause this issue. If you can boot into iOS, first check the iPad's Panic Logs to see if the iPad is creating a crash report when it restarts.
An example of panic log files you'll find in the iPad when it has been randomly restarting.
For this model, look for where it says "no successful checkins from thermalmonitord" ... "Missing sensor(s):"
If you see:
- TG0B - It's an issue with the battery or battery connector
- Make sure the battery screw is fully tightened.
- Check the pins on the battery connector to ensure they are not damaged.
- Try a known-good battery.
- (?) - It's a faulty screen
- Try a known-good display.
- Even if the screen appears to be fully functional it may be defective and causing the iPad to restart.
