| Xbox Elite Wireless Controller | |
| Manufacturer | Microsoft |
| Code name | Model 1698 |
| Release date | October 27, 2015 |
Xbox Elite Wireless Controller side angle
Xbox One Elite Controller (Model 1698) - underside
Elite Controller with chatpad and paddles back
Elite controller with chatpad back without paddles
Chatpad box
Chat pad and headset with box
Headset with chatpad box
Chatpad bottom
Chatpad side
Chatpad front
Xbox one headset adapter
Xbox Wireless Adapter for Windows 10 (Model 1790)
Wireless Adapter for Window with cap removed
The Xbox One Elite Controller is a premium controller based on the second generation of standard Xbox wireless controllers. It was initially bundled with the Xbox One Elite console as well as being sold as a standalone controller. The controller uses a steel construction with a soft-touch plastic exterior, along with interchangeable rear paddle buttons and analog stick tops.
The Elite controller is the ultimate Xbox One controller. Released in 2015, this was the Xbox One's first premium controller and the most expensive to date. Features that make the Elite stand out from all other Xbox One controllers is the fact that parts of it can be swapped for other parts. For example, the left and right sticks can be exchanged for sticks of different shapes. The D-Pad can also be swapped for numerous different forms. Another feature that makes the Elite stand out is the rear paddles on the back of the controller, no other Xbox One controller (that is not in the Elite series) features this.
On June 15, 2015, during its E3 2015 press conference, Microsoft unveiled the Xbox One Elite Wireless Controller, a new controller which Xbox division head Phil Spencer described as being "an elite controller for the elite gamer". It features a steel construction with a soft-touch plastic exterior, along with interchangeable rear paddle buttons (with either short or long forms), analog stick tops (original Xbox One stick, a convex dome, and an extended version for increased accuracy), and directional pad designs (either the traditional four-way design, or a concave disc-like design), and "hair trigger locks" for the triggers that allow users to reduce the amount of distance required to register a press. Through software, users can customize button and paddle mappings and adjust the sensitivity of the triggers and analog sticks. Two button profiles can be assigned to a switch on the controller for quick access. The Elite Controller was released on October 27, 2015.
The Xbox Elite Wireless Controller, internally known as Model 1698 is a game controller released by Microsoft on October 27. 2015. It is a pro-orientated version of the Xbox Wireless Controller.
Being a pro-orientated version of the Xbox Wireless Controller, the Xbox Elite Wireless Controller has magnetic-attached thumbstick caps, swappable D-pads, 2-step trigger stops and remappable back paddles. As will Model 1697 of the Xbox Wireless Controller, it has a 3.5mm audio jack for audio passthrough. Impulse trigger rumble is also supported, but disabled if shorter trigger stop setting is set. It is powered by 2 AA batteries when used for wireless connection.
It was superseded by Xbox Elite Wireless Controller Series 2 (Model 1797) on November 4, 2019.
The Xbox Elite Wireless Controller is a native XInput controller, meaning it is supported in games that use XInput API. It supports impulse triggers in selected games. Up to 2 built-in profiles and up to 256 profiles in the cloud can be customized using Xbox Accessories App on Xbox One, Xbox Series X|S, and Windows PC (Requires Windows 10 and later), but thrid-party software like Steam, reWASD, and JoyShockMapper allow assigning paddles to keyboard and mouse actions or macros. The controller can be connected through either wired (via Micro-USB), or wireless via the Xbox Wireless Adapter for Windows (supports up to 8 controllers). While not natively support Bluetooth connectivity, it can be done by using a Bluetooth adapter like Brook X ONE Adapter. Playing games that only use DirectInput API requires wrappers that transcode the XInput inputs into DirectInput inputs.
Cosmetic variants
A special Gears of War 4-themed limited-edition variant of the Elite controller was unveiled during Microsoft's E3 2016 press conference. It features a rustic, dark red color scheme with a blood splatter effect and the series emblem on the rear of the controller, and a D-pad disc with weapon symbols corresponding to the in-game weapons bound to these controls.
A White Special Edition of the controller was announced on August 29, 2018. Although a revised Elite controller was leaked early in 2018 incorporating functional changes, the White Special Edition was another cosmetic variant of the original Elite.
Chat Headset
Stereo Headset Adapter
Chatpad
