| How to Fix an iPad Pro 10.5 That Randomly Restarts | |
| Device | IPad Pro 10.5 |
| Affects part(s) | motherboard |
| Needs equipment | |
Device keeps restarting, either after staying stuck on the Apple logo for the entire time or after fully booting into iOS. Device may restart randomly or at regular intervals.
- iPad restarts on its own.
- May be stuck on the Apple logo or may fully boot but then restart after a minute or randomly.
If the issue has a single, specific solution, provide it in this section and delete the sub-headers below. Otherwise, if there are multiple potential causes for the problem, outline the process of identifying the root cause and offer corresponding solutions below. There are a few common faults that cause this issue. If you can boot into iOS, first check the iPad's Panic Logs to see if the iPad is creating a crash report when it restarts.
