Nintendo Switch No Backlight Repair
Revision as of 16:33, 13 January 2024 by ASRepairs (talk | contribs)
Device Nintendo Switch
Type Soldering, Cleaning
No Backlight on a Nintendo Switch diagnostics and repair.
  • No Backlight on LCD
  • Make sure that the screen is working by using a flashlight.
  • Check for corrosion on the backlight-connector, if corroded change port and repair cable.
  • The backlight-ic is on the backside of the board. Check this TPS61163A-Chip for corrosion and replace if you have any shorts around it.
