Nintendo Switch No Backlight Repair | |
Device | Nintendo Switch |
Needs equipment | |
Type | Soldering, Cleaning |
No Backlight on a Nintendo Switch diagnostics and repair.
- No Backlight on LCD
- Make sure that the screen is working by using a flashlight.
- Check for corrosion on the backlight-connector, if corroded change port and repair cable.
- The backlight-ic is on the backside of the board. Check this TPS61163A-Chip for corrosion and replace if you have any shorts around it.
