Nintendo Switch No fan spin and not charging joycons Repair
Revision as of 14:29, 13 January 2024 by ASRepairs (talk | contribs)
Device Nintendo Switch
No fan spin and not charging joy-cons
  • No fan spin
  • not charging joy-cons
  • Issues with fan circuit. You can use a voltage injection trick where you briefly inject voltage into the fan (in circuit) to bring the mosfet back to life. Here's A Guide. If voltage injection doesn't work, replace the mosfet above M92T36.
  • Issue can also be caused by a bad CPU fan.
