| Nintendo Switch No fan spin and not charging joycons Repair | |
| Device | Nintendo Switch |
| Affects part(s) | |
| Needs equipment | |
| Difficulty | |
| Type | |
No fan spin and not charging joy-cons
- No fan spin
- not charging joy-cons
- Issues with fan circuit. You can use a voltage injection trick where you briefly inject voltage into the fan (in circuit) to bring the mosfet back to life. Here's A Guide. If voltage injection doesn't work, replace the mosfet above M92T36.
- Issue can also be caused by a bad CPU fan.
