| How to fix iPhone 14 Error 9 with failed Rose | |
| Device | iPhone 14, iPhone 14 Plus |
| Needs equipment | Soldering Iron, Hot Air Station, Reballing Stencil |
iPhone 14 fails to restore and throws Error 9 during iTunes / 3uTools restore. The restore process may begin normally but fails mid-way.
Upon inspecting the restore logs, communication failure is traced to the ROSE IC, confirming a hardware fault.
This issue requires board-level repair and cannot be resolved via software.
- Restore fails with Error 9
- Device stuck in Recovery or DFU mode
- Restore progresses partially, then fails
- Same behavior with:
- Different cables
- Different computers
- DFU restore
- Restore logs indicate ROSE communication failure
- Attempt restore via iTunes / 3uTools
- Confirm consistent Error 9
- Review restore logs
- Look for ROSE-related errors
- Rule out:
- Bad cable
- Faulty charging port
- Low battery voltage
- Confirm issue persists in DFU mode
Once logs confirm ROSE fault → proceed to board repair.
1. Prepare the Board
- Remove logic board from device
- Remove shields as necessary
- Protect sensitive components
2. Split the Sandwich Board
- Apply controlled preheat
- Separate upper and lower layers carefully
- Avoid warping or pad damage
⚠️ Excessive force can destroy interposer pads.
3. Remove ROSE IC
- Apply flux
- Remove faulty ROSE IC using controlled hot air
- Clean pads thoroughly
- Inspect for lifted pads or trace damage
4. Replace ROSE IC
- Install new known-good ROSE IC
- Align precisely
- Reflow evenly
- Inspect solder joints under microscope
5. Re-stack the Board
- Re-align sandwich layers
- Reflow evenly to restore board connection
- Inspect for alignment integrity
6. Post-Repair Testing
- Reassemble device partially using iSocket
- Attempt restore again
- Confirm restore completes successfully
- Verify normal boot
