How To Fix an iPhone 15 That Randomly Restarts
Revision as of 00:17, 11 February 2026 by VCCBoardRepairs (talk | contribs) (Added Decimal Values)
Device iPhone 15, iPhone 15 Plus
Difficulty ◉◌◌◌ Easy
Type Part replacement
There are many reasons that could cause an iPhone 15 and iPhone 15 Plus to randomly restart every few minutes. For the iPhone 15 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 15 series are:
  • Back Glass/Wireless Charging Flex- This is the flex that is attached to the Back Glass. It can damaged during a drop or screen replacement
  • Proximity Flex -This is the flex that is attached to the screen. It can easily be liquid damaged or torn during a screen replacement.
  • iPhone 15 - FPCs to Inspect for 3 Min Restart
If you see:
  • 0x200000 (or 2097152) - it's the Wireless Charging Flex (Back Glass)
    • Could be a sandwich issue
  • 0x80000 (or 524288) - it's the Charging Port Flex and/or Air Pressure Sensor
    • iPhone 15 - Charging Port Flex
      Make sure this flex is plugged in
    • Make sure the Air Pressure Sensor is plugged in
    • Test with OEM or Premium. Aftermarket parts have a high defect rate
    • iPhone 15 Air Pressure Sensor
  • 0x100000 (or 1048576) - it's the Proximity Flex Cable
  • 0x280000 (or 2621440) - it's the Wireless Charging Flex + Charging Port Flex
    • Make sure both flexes are plugged in
  • 0x380000 (or 3670016) - it's the Wireless Charging Flex + Charging Port Flex + Proximity Flex
    • Make sure all 3 flexes are plugged in
  • 0xa1 (or 161) - It's a battery data issue.
    • Sometimes you'll see the battery percentage fluctuate or you'll randomly get a "non-genuine" message.
    • Check the battery connector pins. Sometimes they can bend out & battery won't make good contact.
    • Diode mode the battery connector pins & compare them to known good board
    • Test with a known good battery
    • Replace the battery connector
    • Check battery connector voltage. Read this guide for more details: IPhone 15 Pro Stuck at 1 Percent Charging and No Battery Data 0xa1 Panic Log Code
  • Bad or damaged flex
