A2992 Stuck on 5V and 0.02A Current Draw
Revision as of 16:24, 20 January 2026 by CRC2018 (talk | contribs) (added full details of the repair)
Device
Affects part(s)
Needs equipment
Difficulty
Type
  • Symptom 1 (Figure 1)
  • Symptom 2
Check USB C Ammeter stuck at 5V and low current draw
Check if PPBUS_AON and PP3V8_AON are present
Proceed to visual inspection of area around C7762 for corrosion
Clean area around C7762 of corrosion
Remove or replace any shorted caps around C7762
Test and repair any corroded traces.
