IPhone Upper-Layer Compatibility Guide (Sandwich Logic Boards)
Revision as of 22:39, 19 January 2026 by IamMyron07 (talk | contribs) (Created page with "{{Explanatory Guide}} == What Is the “Upper Layer”? == On modern iPhones with sandwich (two-layer) logic boards, the board is split into: * Upper layer – CPU, NAND, Logic EEPROM * Lower layer – Baseband, WiFi and NFC (in some models) An upper-layer swap means transferring the entire top board from one device to another, usually to recover data or restore functionality when the upper layer is damaged. == Compatibility by iPhone Generation == {| class="wikitabl...")
Type
Device(s)
Difficulty
  • Upper layer – CPU, NAND, Logic EEPROM
  • Lower layer – Baseband, WiFi and NFC (in some models)
iPhone Generation Models in Generation Upper Layer Swap Compatibility BOARD ID RESISTOR
iPhone X Series X ✅ Same model only
XS ⚠️ Compatible only with XS (PMIC-specific)
XS Max ⚠️ Compatible only with XS Max (PMIC-specific)
iPhone 11 Series 11 ✅ Same model only
11 Pro ✅ Compatible with 11 Pro Max (Board ID mod required)
11 Pro Max ✅ Compatible with 11 Pro (Board ID mod required)
iPhone 12 Series 12 ✅ Same model only
12 Mini ✅ Same model only
12 Pro ✅ Same model only
12 Pro Max ✅ Same model only
iPhone 13 Series 13 ✅ Same model only
13 Mini ✅ Same model only
13 Pro ✅ Same model only
13 Pro Max ✅ Same model only
iPhone 14 Series 14 ✅ Compatible with 14 Plus (Board ID mod required)
14 Plus ✅ Compatible with 14 (Board ID mod required)
14 Pro ✅ Compatible with 14 Pro Max (Board ID mod required)
14 Pro Max ✅ Compatible with 14 Pro (Board ID mod required)
iPhone 15 Series 15 ✅ Compatible with 15 Plus (Board ID mod required)
15 Plus ✅ Compatible with 15 (Board ID mod required)
15 Pro ✅ Compatible with 15 Pro Max (Board ID mod required)
15 Pro Max ✅ Compatible with 15 Pro (Board ID mod required)
iPhone 16 Series 16
16 Plus
16 Pro ✅ Compatible with 16 Pro Max (Board ID mod required)
16 Pro Max ✅ Compatible with 16 Pro (Board ID mod required)
iPhone 17 Series 17
17 Pro ✅ Compatible with 17 Pro Max (Board ID mod required)
17 Pro Max ✅ Compatible with 17 Pro (Board ID mod required)
