How To Repair Nintendo Switch WiFi Not Working
Revision as of 12:46, 23 November 2025 by IamMyron07 (talk | contribs) (Created page with "{{stub}} {{Repair Guide |Device=Nintendo Switch Lite |Affects parts=Logic Board |Needs equipment=Hot Air Station, Soldering Iron, Tweezers, Reballing Stencil |Type=Soldering |Difficulty=4. Specialist }} == Problem description == Nintendo Switch Lite shows error 2110-1118, cannot connect to WiFi, no networks appear, or WiFi toggle is greyed out. This fault commonly occurs due to: # Failed WiFi IC (Broadcom) # Missing / knocked-off resistors next to the USB-C port after...")
Device Nintendo Switch Lite
Affects part(s) Logic Board
Needs equipment Hot Air Station, Soldering Iron, Tweezers, Reballing Stencil
Difficulty ◉◉◉◉ Specialist
  1. Failed WiFi IC (Broadcom)
  2. Missing / knocked-off resistors next to the USB-C port after a previous repair.
Nintendo Switch Lite - WiFi Not Working
Nintendo Switch Lite - WiFi IC Location
  • WiFi toggle missing or greyed out
  • “Error Code: 2110-1118” when searching for networks
  • No networks detected
  • Bluetooth may also be affected (shares the same IC)
  • Issues appear immediately after board repair (port replacement, power IC work, etc.)
1. Software Ruling-Out
  • Try factory reset (no data loss) → Settings → System → Formatting Options → Reset Cache
  • Try full initialize (if customer approves)
  • If WiFi toggle is missing: hardware fault confirmed
Nintendo Switch Lite - Missing Resistors Next to the Type C Charge Port
2. Visual Inspection (Board Level)
  • Inspect the board area around USB-C
    • Look specifically for knocked-off resistors near the area circled in the provided image
  • Inspect WiFi IC for:
    • Overheating marks
    • Reflow attempts
    • Physical damage
    • Cold solder pads
      Nintendo Switch Lite - Missing Resistors Soldered Back
Nintendo Switch Lite - WiFi Fixed Successfully After Replacing WiFi IC or Replacing Damaged/Missing Resistors
Case 1 — WiFi IC Replacement
1. Remove Old WiFi IC
  • Preheat board
  • Lift carefully to avoid pad damage
2. Install Donor WiFi IC
  • Important: Only use an original IC pulled from a donor Switch Lite
  • Reball
  • Align and reflow
  • Inspect for bridges under microscope
3. Testing
  • Reassemble partially
  • Power on → WiFi toggle should appear immediately
  • Connect to network to confirm functionality
Case 2 — Replace Missing Resistors Near USB-C
Common Fault
  • One or more of the 4 tiny SMD resistors near the USB-C port are missing
  • Usually damaged during USB-C desoldering
Steps
  1. Clean area with flux
  2. Inspect pads for ripping
  3. Replace missing resistors
    • match values from donor board
  4. Microscope inspection for bridges or cold joints
  5. Reassemble and test WiFi
  6. WiFi should function properly
