How To Repair Samsung Galaxy Z Fold 4 Fake Charing
Revision as of 16:05, 20 November 2025 by IamMyron07 (talk | contribs) (→‎Problem description)
Device Galaxy Z Fold 4 5g
Affects part(s) Motherboard
Needs equipment Hot Air Station, Soldering Iron, Tweezers, Donor board/New IC, Flux, Soldering Wick
Difficulty ◉◉◉◉ Specialist
Samsung Z Fold 4 displays the charging animation but never boots. Acts as if charging but battery percentage does not increase.
Z Fold 4 5G - Fake Charging
Z Fold 4 5G - ASL01 Charging IC
  • Shows charging symbol only
  • Stays stuck on charging logo
  • Battery percentage does not increase
  • Phone does not power on normally
  • V_BATT line measuring 0 Ω (dead short)
The failure is caused by a short on the V_BATT power rail, usually due to a failed ASL01 power IC.
Removing the IC clears the short; replacing it resolves fake charging permanently.
Z Fold 4 5G - VBATT Line Diode Mode Reading
Z Fold 4 5G - ASL01 IC Location On BoardView
1. Visual Inspection
  • Check the mainboard for corrosion or burn marks.
  • Inspect USB-C daughterboard, battery connector, and PMIC areas.
  • Ensure no aftermarket battery is causing brownout behavior.
2. Diode Mode – V_BATT Rail Check
  • Probe the V_BATT test point / capacitor bank near the FPC connectors.
  • Expected normal reading: typically in the hundreds of kΩ or >1MΩ.
  • Faulty board reading : 0.09 Ω → confirmed short.
3. Short Hunting
  • Use multimeter continuity across the V_BATT line.
  • Use thermal cam or voltage injection (1 V, limited to 1–2 A).
  • In this case, no component heated visibly during first injection.
  • Move to boardview/diagram → V_BATT rail maps to ASL01 Charging IC (Located right next to the Battery Connector FPC).
4. Confirm Shorted IC
  • Apply rosin + re-inject voltage.
  • ASL01 IC heats up → confirmed bad component.
1. Remove the Faulty ASL01 IC
  • Mask surrounding components with high temperature tape.
  • Apply hot air.
  • Gently lift the ASL01 IC.
2. Re-Test the V_BATT Rail
  • Measure at same point as initial short.
  • After IC removal: reading becomes 19 MΩ.
  • This confirms the short is fully cleared.
3. Install New ASL01 IC
  • Clean pads with solder wick + flux.
  • Apply fresh leaded solder.
  • Reball or use pre-balled IC.
  • Align and solder the new ASL01 Charging IC.
4. Final Measurement
  • After reinstallation, check V_BATT again:
    • Reading becomes 2.16 kΩ / .469V (normal range from reference).
5. Assemble & Boot Test
  • Reconnect battery and screen.
  • Phone now boots normally and charges correctly.
