| Device(s) | PlayStation 5, PlayStation 5 Slim, PlayStation 5 Pro |
| Difficulty | |
What are Errlogs ?
| Code | Description |
| 8000000A | VRM HOT Fatal |
| 80850000 | VRM CPU (2) |
| 80860000 | VRM GPU(6) |
| 808D0002 | Thermal Shutdown : Local Sensor 2 “Problem with the temperature sensor on the LED board — check the flex cable/LED Board. If the error happens without the flex and LED Board connected the Southbridge is probably faulty. Name of the faulty line [THERMISTOR_2_LED]” |
| 80801101 | RAM GDDR6 1 |
| 80801102 | RAM GDDR6 2 |
| 80801103 | RAM GDDR6 1 2 |
| 80801104 | RAM GDDR6 3 |
| 80801105 | RAM GDDR6 1 3 |
| 80801106 | RAM GDDR6 2 3 |
| 80801108 | RAM GDDR6 4 |
| 80801109 | RAM GDDR6 1 4 |
| 8080110A | RAM GDDR6 2 4 |
| 8080110C | RAM GDDR6 3 4 |
| 80801110 | RAM GDDR6 5 |
| 80801111 | RAM GDDR6 1 5 |
| 80801112 | RAM GDDR6 2 5 |
| 80801114 | RAM GDDR6 3 5 |
| 80801118 | RAM GDDR6 4 5 |
| C0020303 | Main SoC Access Err (SB-TSI I2C) |
| 80050000 | SoC VRM Power Fail (CPU) |
| 80801028 | Fatal Shutdown by OS request |
| C0810002 | HDMI Tx Access Error (Failure in the 1.8V power line of the HDMI Encoder) Name of the faulty line: [1.8V_HDMI] File:C0810002.jpeg |
| 80918000 | SSD PMIC Error (DA9081\RT5127 failure in the 0.8V line) Name of the faulty line: [0.8V_FC_VDD] File:80918000.jpeg |
| 80912000 | SSD PMIC Error (DA9081\RT5127 failure in the 2.5V line) Name of the faulty line: [2.5V_DDR4_VPP] File:80912000.jpeg |
| 80910200 | SSD PMIC Error (DA9081\RT5127 failure in the 1.2V line) Name of the faulty line: [1.2V_FC_VDDQMIO] File:80910200.jpeg |
| 80910002 | SSD PMIC Error (DA9081\RT5127 failure in the 1.8V line) Name of the faulty line: [1.8V_FC_AVDD] File:80910002.jpeg |
| C00C0002 | VRM Controller Access Error (failure in the 3.3V VRM line) Name of the faulty line: [3.3V_VRM] |
| 80C00140 | Force Shutdown Power Button Pressed for 10 sec |
| 80910800 | SSD PMIC Error (Failure in the 1.2V_FC_VDDQFIO line) Name of the faulty line: [1.2V_FC_VDDQFIO] |
| 808B00FF | SSD Controller Watchdog Error |
| C0160203 | PMIC (SSD) Access Error(Playstation 5 Slim Check F7004) File:C0160203.jpeg |
| B0088108 | Sonics Bus Error |
| 808C0D91 | USB Type-C Error |
| 80802081 | Communication failure between the SSD controller and the APU — check the capacitors behind the controller. File:80802081.jpg |
| 808010A5 | Fatal Shutdown by OS request — I once had a PS5 Pro with this error and couldn’t figure it out. (IF YOU HAVE INFO PLEASE UPDATE THE WIKI) |
| 8091C000 | SSD PMIC Error |
| C0920002 | USB Type-C Redriver Access Error |
| 808B0014 | Flash Controller: Watchdog Timer (Related to the SSD) |
| 80871055 | Flash Cont (Related to the SSD) |
| 80800014 | Fatal Shutdown by OS request — supposedly related to the TPM chip. |
| 8080001A | Fatal Shutdown by OS request |
| 80800022 | Fatal Shutdown by OS request |
| 80871001 | Flash Cont: ScCmd Response Error |
| 80871062 | Flash Cont: ScCmd Response Error |
| 80894003 | Flash Cont: Boot EFC Error |
| 808940AE | Flash Cont: Boot EFC Error |
| 808C2092 | USB Type-C Error |
| 80D00402 | USB-BT Error (Download Firmware) |
| 808011A0 | RAM GDDR6 (Bank 6,8) - Single Beep, 1 second blue light, off. |
| B0082108 | Supposedly related to the Wi-Fi chip. |
| 80801F12 | APU problems (Try reballing). |
| 808300F1 | Found in DB no info |
| 80060004 | Problem in a VRM |
| E31223DE | Related to the Southbridge — clean the flux underneath or let it cool down. |
| E2E00F1D | Related to the Southbridge — clean the flux underneath or let it cool down. |
| E2000000 | Related to the Southbridge — clean the flux underneath or let it cool down. |
| E1200000 | Related to the Southbridge — clean the flux underneath or let it cool down. |
| 80808888 | Fatal Shutdown by OS request |
| C0810303 | Found in DB no info |
