| Device | PlayStation 5, PlayStation 5 Slim, PlayStation 5 Pro |
| Needs equipment | |
| Difficulty | |
| Type | Troubleshooting/Diagnostics"Troubleshooting/Diagnostics" is not in the list (Soldering, Teardown, Part replacement, Cleaning, Software, BGA, General) of allowed values for the "Repair Guide type" property. |
What are Errlogs ?
| Code | Description |
| 8000000A | VRM HOT Fatal |
| 80850000 | VRM CPU (2) |
| 80860000 | VRM GPU(6) |
| 808D0002 | Thermal Shutdown : Local Sensor 2 (Problema no sensor de temperatura na placa dos LEDs verificar FLEX) Nome da linha em falha [THERMISTOR_2_LED] |
| 80801101 | RAM GDDR6 1 |
| 80801102 | RAM GDDR6 2 |
| 80801103 | RAM GDDR6 1 2 |
| 80801104 | RAM GDDR6 3 |
| 80801105 | RAM GDDR6 1 3 |
| 80801106 | RAM GDDR6 2 3 |
| 80801108 | RAM GDDR6 4 |
| 80801109 | RAM GDDR6 1 4 |
| 8080110A | RAM GDDR6 2 4 |
| 8080110C | RAM GDDR6 3 4 |
| 80801110 | RAM GDDR6 5 |
| 80801111 | RAM GDDR6 1 5 |
| 80801112 | RAM GDDR6 2 5 |
| 80801114 | RAM GDDR6 3 5 |
| 80801118 | RAM GDDR6 4 5 |
