How To Repair an iPhone 11 that is bootlooping
Revision as of 11:55, 28 September 2025 by IamMyron07 (talk | contribs) (Created page with "{{Repair Guide|Device=iPhone 11|Affects parts=Main Logic Board|Needs equipment=Solering Iron, Hot Air Station|Difficulty=3. Hard|Type=Soldering}} == Problem Description == This guide documents an iPhone 11 that was stuck in a bootloop due to a shorted I2C_AOP_SDA line caused by a faulty Audio IC (U4700). Replacing the Audio IC resolves the short and allows the phone to boot normally. ---- == Symptoms == * Device bootloops endlessly (Apple logo → restart → repeat)...")
Device iPhone 11
Needs equipment Solering Iron, Hot Air Station
Problem Description
  • Device bootloops endlessly (Apple logo → restart → repeat)
  • No visible liquid damage or physical impact
  • Restores with iTunes/3uTools fail or hang
  1. Initial Test Connect to DCPS → observe repeated current spikes and drops consistent with bootloop.
  2. Check I2C Lines Measure resistance to ground on I2C_AOP_SDA and I2C_AOP_SCL.
    • I2C_AOP_SDA found shorted to ground.
  3. Isolate Fault I2C_AOP_SDA line runs under U4700 (Audio IC). Remove U4700 → re-measure line → short clears.
  4. Confirm Diagnosis Test boot with U4700 removed → phone boots into iOS normally (without audio). This confirms U4700 was the cause of the short.
  1. Remove U4700 Audio IC.
  2. Clean pads on PCB and prepare a replacement U4700 (new or donor).
  3. Reball or use pre-balled replacement IC, re-install onto board.
  4. Power on and verify I2C_AOP_SDA line is no longer shorted.
  5. Confirm full boot into iOS and test all audio functions (speaker, mic, earpiece).
