| Galaxy A515 Black Screen After 1st logo | |
| Device | Galaxy A51 |
| Type | Soldering, BGA |
Insert paragraph
If you receive a device in this condition it will be showing a black screen after the 1st(boot logo)
The symptoms of the device should meet all the symptoms below on order to proceed to repair:
- Device shows 1st logo(boot logo) and after that screen goes black and stays on black screen forever and does not go to the 2nd logo at all (see the reference pics below)
- The device does not go the home screen with screen connected(without screen connected the device turns on completely and you can feel the vibrator motor)
- Phone must NOT bootloop ( shows the samsung logo again and again) and should stay on black screen
This issue occurs due to a water damage to a display, there are 2 possible fixes:
- The obvious one is to change the display and the issue will be fixed
- There is a way to repair the same display with just 1 jumper, follow the steps below in order to repair the device:
- Pretin the pads #5 and #7 as shown in the picture
- Make a jumper on these 2 pads with 0.02mm jumper wire like shown in the pictures below
- Solidify the connection with uv
- Now check, your device should be fixed
