How To Repair IPad 6 No Power
Revision as of 18:32, 30 November 2025 by IamMyron07 (talk | contribs) (→‎Symptoms)
Device IPad 6
Affects part(s) MainLogic Board
Needs equipment Hot Air Station, Soldering Iron, Tweezers, Microscope, Solder wick, Solder Paste, Reballing Stencils, Flux
Difficulty ◉◉◉◉ Specialist
iPad 6 shows no signs of life (no boot, no display, no vibration, no charging icon).
When connected to a DC Power Supply (DCPS), the device either:
  • Current spikes directly to 1 A & above (dead short)
  • Jumps directly 0.150 A and resets (partial boot but fails)
This model commonly suffers from shorts on VCC_MAIN, Tristar failure, or WiFi IC/PMU shorts.
*NOTE: A proper boot sequence should be 0.050 -> 0.060 -> 0.100 -> and climbing till it reaches 1.00 A*
Example of iPad 6 WiFi IC (Figure 1)
  • Completely dead, no Apple logo
  • No reaction on charger
  • No heat except possibly near shorted component
  • DCPS shows high current
Example of shorted WiFi IC on iPad 6 under thermal camera view
iPad 6 WiFi IC on BoardView Software (Figure 2)
1. Check Battery Voltage
  • A healthy iPad 6 battery should read 3.7–4.2 V
  • If battery is at 0 V, iPad may appear dead
2. Try DC Power Supply Boot
  • Connect directly to board
  • Observe current draw:
Current Behavior Likely Fault
Instant spike above 1.00 A Possible short on VCC_MAIN, WiFi IC or PMIC
Instant spike to .150A and cycling back Tristar failure
3. Check for VCC_MAIN Short
  • Multimeter to diode mode → red probe ground
  • Black probe on VCC_MAIN caps
  • Reading close to 0.000 = short
4. Inspect Charging IC Region
  • Check under thermal camera/rosin flux for a bad Charging IC.
5. Check WiFi Section
  • Check under thermal camera/rosin flux for a shorted WiFi IC.
1. Remove the Board
Separate battery first, remove board from chassis.
2. Identify Fault
Based on DCPS + thermal/rosin method:
  • Shorted capacitor? → Replace
  • Hot WiFi chip? → Replace
  • Tristar short? → Replace Tristar
3. Fix the Short
  • Replace burnt/shorted capacitor
  • Replace WiFi IC
  • Replace Hydra charging IC
4. Reassemble & Test
  • Confirm proper current pattern
  • Confirm charging
  • Confirm successful boot
  • Run WiFi test
  • Plug into iTunes/PC for recognition
