- Power / Yellow
- Charging / Green
- Power Fault / Red
- Charging Fault / Red
Relay / contactor information
![](/images/thumb/8/8f/HCS-contactor.jpg/300px-HCS-contactor.jpg)
Two of the fault codes above involve a failed contactor, one of the few mechanical items in the assembly and thus more prone to failure. This part is a 40-Amp, 2-pole contactor with metal mounting plate and screw terminal capability. When terminating wires into it, crimp ferrules onto the wire ends.
American Zettler | XMC0-402.IBBx (x=C? D?) | RS Online (out of stock) | DigiKey (high volume, long lead) | unknown but likely highest quality |
Background / failure modes
- High ground leakage
More product photos
![](/images/thumb/1/1c/HCS-inside.jpg/300px-HCS-inside.jpg)
![](/images/thumb/e/e9/HCS-circuitboard.jpg/300px-HCS-circuitboard.jpg)
