More advanced LED codes table from CC's "HCS Troubleshooting Guide". Note that the number of blinks of the two bottom red LEDs is important. If two blinks, then the line 1 side of the contactor is failing; if three blinks, then line 2.
![](/images/thumb/e/ee/HCS-fault-codes.png/300px-HCS-fault-codes.png)
Relay / contactor information
![](/images/thumb/8/8f/HCS-contactor.jpg/300px-HCS-contactor.jpg)
Two of the failure modes involve the contactor. This is a Hongfa XMC0-402.IBBD , which is a 40-Amp, 2-pole contactor; see Hongfa's website for more on the XMC0 series. The Hongfa contactors catalog (PDF) includes XMC0 part number details on page 5/22, and cross references to other companies on page 2/22 (e.g. Tyco, Siemens). Other HCS-series units may have different make and model of contactors in them, but they should be drop-in replacements / compatible.
Background / failure modes
- High ground leakage
More product photos
![](/images/thumb/1/1c/HCS-inside.jpg/300px-HCS-inside.jpg)
![](/images/thumb/e/e9/HCS-circuitboard.jpg/300px-HCS-circuitboard.jpg)
