Information about DIY repair of the ClipperCreek HCS series, which includes the HCS-40 and HCS-60 models.
More advanced LED codes table from CC's "HCS Troubleshooting Guide":
![](/images/thumb/e/ee/HCS-fault-codes.png/300px-HCS-fault-codes.png)
- High ground leakage
